Activity › Forums › Adobe Premiere Pro › Monitoring DVCPRO HD
Posted by Jason Henries on December 23, 2008 at 7:58 pmI’m sure this question has been answered before but I couldn’t find it after doing numerous searches. So I apologize for the redundancy.
Is there any way to monitor DVCPRO HD on either a separate LCD monitor or an HDTV from CS4 without dropping cash on a Matrox or similar card?
I don’t need all the RTFX acceleration, I just want to see my raw HD footage on a full-size display.
I don’t need the capture functionality either. I always import from P2 and export to disc or web. I just need to monitor the footage. That’s it. I don’t care if I have to preview render dissolves, etc. I just want to see it on a larger screen.
If this hasn’t been invented yet, someone should. How hard could it be?
Arc Nevada replied 17 years, 7 months ago 6 Members · 24 Replies -
Vince Becquiot
December 24, 2008 at 7:02 amYou could always drop a small amount of cash ($250.00) on a Blackmagic intensity. That’ll get you HDMI or Component out (and in).
The problem is that if you shoot 24PN or 30PN like many people who use P2, none of these cards will support it (not even the nice AJA series).
I’ve heard that CS4 now supports preview on a second monitor. I don’t need it so I never checked into it, but maybe someone else did.
Vince Becquiot
Director | EditorKaptis Studios
San Francisco – Bay Area -
Bo Skelmose
December 24, 2008 at 10:23 amI have a Toshiba Qosmio G30 notebook – it outputs the timeline player window on the HDMI output. Looks greaet in HD. There must be some graphic cards for Staionary PC’s that is capable of that too.
Mike Cohen
December 24, 2008 at 3:36 pmYou can indeed monitor timeline playback on a 2nd monitor in CS4 via the Sequence settings drop-down. Actually you can do it in CS3 but you need to setup your project to work this way from the start.
Make sure you make your Premiere only occupy one screen, or you can lose access to some windows.
HDV looks sweet even though it is conforming to the monitor’s resolution and dimensions, one can imagine DVCPRO would as well. Seems very dependent upon a good display card. I have a GeForce 8500 GT, it plays pretty smoothly, but there is a slight pause between starts and stops of the timeline. Obviously you can spend thousands on a display card alone.Mike Cohen
Jason Henries
December 24, 2008 at 5:25 pmThanks one and all for your comments.
After hours of searching the ‘net yesterday, I found the resource I was looking for… just as Mike Cohen said.
I’m building a new system for the CS4 production bundle, but not all the bits have arrived yet.
My old system is a P4 2.4GHz with an AGP GeForce FX5900 running CS3. No I/O card. You can imagine HD hurts a bit.
After finding a post here (https://premierepro.wikia.com/wiki/Monitor), I ran down to pick up a cheapie nVidia PCI video card to test in the old system.
I installed the PCI card, hooked up my 37″ 720P TV, and opened CS3. I set up a new project with the “Desktop” custom settings, but left everything as is native to DVCPRO HD 720/60P. I set the playback settings to output to Monitor 2.
The project opened, I imported some DVCPRO HD footy, and voila… my footage was displayed full screen on the TV.
Now for the bad part. It shows raw DVCPRO HD footage as non-native. There’s a red slice over the clip when you drop it on the timeline. It also won’t play back real-time. And rendering the slice takes FOREVER.
So, my question now is… will CS4 allow you to open a “stock” DVCPRO HD 720/60p project, and THEN change the settings to preview on a second (or in my case, 3rd) monitor??? If so, then I think this setup will work in the new system, if not… CURSES!
Anyone have experience?
Vince Becquiot
December 24, 2008 at 5:34 pmThe render line often indicates the wrong type of project for the files on the timeline. Does it only appear after you change the preview to the external monitor ?
If so, like you said, that P4 is way outdated, and given the extra processing required for an external full screen preview, the render bar probably just means that you don’t have the processing power needed to play back native footage, or at least not at high quality.
Any machine like a Core2Duo and above should handle it with no problems, even non native without rendering.
All you need is just a little patience for that new machine I think…
Vince Becquiot
Jason Henries
December 24, 2008 at 5:53 pm[Vince Becquiot] “The render line often indicates the wrong type of project for the files on the timeline. Does it only appear after you change the preview to the external monitor ?”
Nope. It’s there all the time. I even pulled the PCI card out and re-opened the project. The red line remains.
I think the problem is that the “custom” project settings disassociate all of the installed codecs. So Premiere suddenly doesn’t understand that you’re using native footage. Everything has to be rendered.
Some of the “stock” project types will allow you to modify the playback settings without selecting the custom “desktop” setup. DVCPRO HD 720/24 or 30P, for instance will allow me to modify the playback output. 60P won’t.
Maybe CS4 will make the difference. Certainly the new machine will help render times and smooth out playback. I just hope it will recognize that my HD footage IS native.
Oh, and it’s a Quad.
Vince Becquiot
December 24, 2008 at 6:08 pmAlright I reread your post more carefully and here’s what’s probably going on.
If this is truly 60P (not 30P over 60i) and you want it to play on a 60P timeline, you’ll have to interpret the footage as 60P in your project panel.
By default, Premiere converts all 60P footage to the 30P. Very convenient if you like slow motion in a 30P timeline, but I never understood why it did that in a 60P timeline, but that should solve your issue.
Vince Becquiot
Vince Becquiot
December 24, 2008 at 6:15 pmActually, on second thought, that makes sense since I am referring to variable framerate. So I guess my question would be, is that 60P in VFR mode or 60P with audio ?
Either way make sure the project panel indicates 60P.
Vince Becquiot
Vince Becquiot
December 24, 2008 at 6:29 pmSo is it 60P with or without audio ?
Vince Becquiot
