Activity › Forums › Adobe Premiere Pro › Monitoring 2K timelines in Premiere CS6 via Blackmagic DeckLink HD Extreme 3D
  • Monitoring 2K timelines in Premiere CS6 via Blackmagic DeckLink HD Extreme 3D
    Posted by Bruce Ingram on January 2, 2013 at 11:39 pm
    Hey, hoping someone can help me. I just received a DeckLink HD Extreme 3D and while I can get 2K monitoring in Resolve, I can’t get it in Premiere CS6, either from the SDI or the HDMI. Can anyone offer some advice?
    I’m on Windows 7 with the latest Blackmagic drivers.
    Graham Hutchins replied 13 years, 1 month ago 3 Members · 2 Replies
  • Peter Garaway
    January 4, 2013 at 5:52 am
    Hi Bruce,
    Blackmagic relies on your sequence settings, it will not downscale to 1080p on the fly. If you want to output a 2k sequence with Blackmagic you will need a 2k monitor. If you have a HD monitor, you can place your 2k media into a 1080p sequence and output it that way. Be sure to select Scale To Frame Size.
    Best,
    Peter Garaway
    Adobe, Premiere Pro
  • Graham Hutchins
    August 13, 2013 at 6:59 pm
    Hi Bruce,
    Can you please explain why both Resolve and After Effects are capable of sending out a signal that will play back via SDI on a Decklink while working in 2K timelines and comps, but Premiere is not?
    I would really like for this to work at some point, as all the workarounds and half measures (“you can place your 2k media into a 1080p sequence and output it that way. Be sure to select Scale To Frame Size. “) are not really solutions.
    Thanks.
    -Graham
    OSX 10.8.4, Windows 7
    Adobe CS6, CC
    FC Studio 3
    DaVinci Resolve 9
    Octo 2.26GB MacPro, 32 GB RAM
