Activity › Forums › Adobe Premiere Pro › Monitor Window: Source vs. Sequence window question
  • Monitor Window: Source vs. Sequence window question
    Posted by Doug Tonee on September 8, 2008 at 10:25 am
    I am learning Premier CS3, I have never done any video editing either analog or digital.
    I have a fundamental question regarding the monitor window and would very much appreciate an answer that discusses the overview of the monitor window as to how the source window differs from the sequence window, and how their intended to be used independently of one another and collectively.
    Doug
    Doug Tonee replied 18 years ago 2 Members · 2 Replies
  • Eddie Lotter
    September 8, 2008 at 1:35 pm
    The “source view” has several purposes, but is intended for working with a specific clip, while the “program view” shows you what your timeline contains.
    You will find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
  • Doug Tonee
    September 8, 2008 at 5:33 pm
    Thanks Eddie- That makes perfect sense. I will have a go at the free tutorials you referenced.
    Thanks again,
    Doug
