Activity Forums Blackmagic Design Monitor output problems with Decklink HD Pro card
  • Monitor output problems with Decklink HD Pro card
    Posted by Scott Brown on December 14, 2005 at 7:25 pm
    Hi Folks
    We’ve just upgraded our Final Cut Pro suite from a Decklink Extreme to a Decklink HD Pro 4:4:4: card and when we go into log and capture, we’re getting picture roll and breakup in our output monitor which is proving both confusing and annoying.
    We’re feeding the component output from the Decklink into a JVC DT-V1910CGU monitor.
    Anyone elso having similar problems?
    The problem is only on the output monitor during capture and does not affect the actual captured footage. It only seems to be a monitoring issue, however it is frustrating.
    Best wishes
    Scott
    Scott Brown replied 20 years, 9 months ago 3 Members · 3 Replies
  • Portland Animator
    December 15, 2005 at 4:19 am
    Have you selected “Enable 4:4:4 mode” in the BMD system prefs?
    Ed Anderson
    Animator
    ed@animationpdx.com
  • Kristian Lam
    December 15, 2005 at 5:52 am
    Hi Scott,
    If you leave it for a moment, does the picture settle down and work normally?
    regards
    Kristian
    Blackmagic Design
  • Scott Brown
    December 16, 2005 at 10:55 am
    Hi Kristian
    It’s strange…sometimes when I go to log and capture everything is fine, however on most occasions as mentioned, I get picture roll/breakup.
    It does tend to settle down after a while and the good thing is that it does NOT appear to affect what is actually being captured.
    My previous Decklink Extreme exhibited none of these problems.
    Scott
    Midas Multimedia
    11 Ashley Park South
    Aberdeen
    AB10 6RP
    http://www.midas-multimedia.com
