Activity Forums Apple Final Cut Pro Legacy monitor 24p over firewire
  • monitor 24p over firewire
    Posted by Daryl K davis on April 23, 2007 at 7:53 pm
    Can I monitor DVCAM 24p timeline via firewire, or do I need am AJA IO or some such box?
    I thought FCP could add pulldown as the sequence played?
    DK Davis / Editor/ Post Super
    Jeremy Garchow replied 19 years, 4 months ago 5 Members · 17 Replies
  • 17 Replies
  • Jerry Hofmann
    April 23, 2007 at 8:52 pm
    No need for more hardware… FCP does this all by itself. Adds the pulldown when viewing externally back… so just hook up a monitor to a transcoding DV device (camera or deck or ADVC box) and edit.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Daryl K davis
    April 23, 2007 at 9:06 pm
    I must be doing something wrong. When I play back footage in the 24 frame per second sequence it only stays parked on one frame when I start play and jumps to the last frame when I stop play – it doesn’t play back the clip for viewing on an external NTSC monitor.
  • Jerry Hofmann
    April 23, 2007 at 9:10 pm
    mmmmmm. this is supposed to work OK. Might trash your preferences. Running 5.1.4 on OS 10.4.8 or 9 and QT 7.1.5?
    Jerry
  • Chi-ho Lee
    April 23, 2007 at 9:13 pm
    It does indeed work. I offlined an entire feature with this. Are you sure your sequence/media is 23.98 and not 24?
    And are your external video settings correct? All frames, Apple firewire NTSC?
    -CHL
    Chi-Ho Lee
    Film & Video Editor
    Apple Certified Final Cut Pro Trainer
    http://www.chiholee.com
  • Daryl K davis
    April 23, 2007 at 9:17 pm
    Yes, I trashed prefs. Running 5.1.4 on OSX10.4.9 but am only Quicktime 7.1.3. I thought Quicktime Pro didn’t work in 7.1.5 or does one have to re-license it or something?
    Anyways I can scrub through the clip, but it just won’t play back at running speed.
  • Jerry Hofmann
    April 23, 2007 at 9:22 pm
    Update QuickTime… try going up to the latest. Won’t hurt things…
    Jerry
  • Jeremy Garchow
    How are you monitoring?
    What else is connected to your computer?
    How fast are your drives?
    What easy setup did you use?
    Did you have to render your timeline at any time?
    What pull down pattern is selected in the rt menu?
    What kind of computer do you have?
    Do you have a capture card?
  • Daryl K davis
    April 23, 2007 at 9:24 pm
    Sequence media is 24. Shot 24fps super 35mm 3-perf and telecined to DVCAM 29.97 NDF. I reverse telecined to 24fpa. Import media into FCP and trying to edit in a 24fps timeline.
    I can drag the clips into a 29.97 timeline and get an orange bar on top and plays fine over NTSC monitor. Is this what I should edit in? and then copy sequence to a 24fps timeline for outputting EDL for DI when picture is locked?
  • Chi-ho Lee
    April 23, 2007 at 9:27 pm
    There is your issue. You should reverse tele to 23.98 via Cinema Tools. 23.98 will output to 29.97 via FW onto your NTSC monitor. 24fps sequences/media will not output to 29.97 via firewire. One of the hardware cards may do this but I’m not 100% sure. The old Aurora film card used to do this but they’re long gone.
    Chi-Ho
    Chi-Ho Lee
    Film & Video Editor
  • Jeremy Garchow
    April 23, 2007 at 9:29 pm
    You can conform 24 to 23.98 in cinema tools as well.
    Jeremy
