Activity › Forums › Apple Final Cut Pro Legacy › monitor 24p over firewire
Jeremy Garchow
April 23, 2007 at 9:30 pm[Daryl K Davis] ” reverse telecined to 24fpa.”
What do you mean by this?
Daryl K davis
April 23, 2007 at 9:34 pmHow are you monitoring?
– back through my DSR-45 DVCAM deck – component out to SONY PVM1954Q monitorWhat else is connected to your computer?
– strictly editing stationHow fast are your drives?
– Lacie Firewire 800What easy setup did you use?
– DV NTSC 48kHz – 24Did you have to render your timeline at any time?
– it doesn’t indicate that I need to renderWhat pull down pattern is selected in the rt menu?
RT: Safe
Video Quality: Dynamic
Frame Rate: Dynamic
Pulldown Pattern: 2:3:2:3What kind of computer do you have?
MacPro 2×3 GHz-Quad Core Intel XeonDo you have a capture card?
No, but can get an AJA IO LD————————-
DK Davis / Editor/ Post Super
Daryl K davis
April 23, 2007 at 9:36 pm24 frames per second (typo)
Jeremy Garchow
April 23, 2007 at 9:36 pm[Daryl K Davis] “- Lacie Firewire 800”
Are the drives and deck on separate busses?
Jeremy
Daryl K davis
April 23, 2007 at 9:38 pmSo even though I am cutting a feature film I reverse telecine to 23.98?
I do it with HDCAM shows but I always thought a full 35mm feature had to be done at 24 frames per second.
What am I going to run in to down the road when they want the EDL for the DI and such?
Shane Ross
April 23, 2007 at 9:42 pm[Daryl K Davis] “24 frames per second”
TRUE 24fps? Not 23.98? I don’t think that FCP can send a true 24fps signal out thru firewire to play on an external monitor. 23.98 yes, 24fps, no.
Shane
Littlefrog Post
http://www.lfhd.net -
Jeremy Garchow
April 23, 2007 at 9:48 pm[Daryl K Davis] “What am I going to run in to down the road when they want the EDL for the DI and such?”
I’d call the people that are going to do that for you, but you can conform from 23.98 to 24 as well. Call your DI house.
Jeremy
