Activity › Forums › Avid Media Composer › MOJO WITH A FIREWIRE DRIVE PLUGGED IN AT THE SAME TIME?
  • MOJO WITH A FIREWIRE DRIVE PLUGGED IN AT THE SAME TIME?
    Posted by Lee on April 21, 2006 at 11:53 am
    Can this be done?
    Mojo box seems to conflict with the External firestore drive when I connect it to the addtional firewire port on the computer.
    Is there a way of connecting both at the same time?
    Boxx 6200
    Mojo
    Xpress pro HD
    paul
    Anonymous replied 20 years, 5 months ago 3 Members · 2 Replies
  • Alex Alexzander
    April 21, 2006 at 2:25 pm
    You could try a completely separate FireWire BUS. Meaning that you use another FireWire card, plugged into a PCI slot, and that this slot is not on the same bus as the FireWire card used with the mojo.
    I have not tried that myself, but that would be the best possible result. I use Highpoint Rocket Raid controller / SATA II array. That works very well.
    Hope that helps.
    -Alex Alexzander
  • Anonymous
    April 22, 2006 at 4:17 am
    It is true, I run a mojo and an ext drive on a g4 powerbook. I run the mojo firewire straight to the pb. and run the ext drive to a firewire card. everything works great.
