Activity › Forums › Avid Media Composer › Mojo SD
  • Posted by Sean Davison on October 19, 2008 at 6:51 pm
    I have to Media Composer 2.8’s with Mojo SDI. A client wants to finish an HD Project with me that is DVCPro HD and XDCam originated (all already Digitised)
    With the edit work ok with the Mojo SDI’s monitoring audio and SDI Output to an SD Monitor? Avids blurb says it will down res the image – is this true? We’re running on Macs and have had loads of firewire issues with the mojo’s,
    Pedro Ithier replied 17 years, 6 months ago 3 Members · 2 Replies
  • Mark
    October 20, 2008 at 10:31 am
    I have recently completed some work in DVCPROHD (P2) on a similiar set-up to yours and had no issues. I could see my work on the SD monitor….but After bringing everything into MC, I switched my HD project to SD 30i NTSC (in the format tab)….So effectively I was working in SD….once the project was complete, I switched back to HD for final exports etc. I also watched my HD project on the full-screen playback using the second monitor. I have not yey worked with XDCAM, so I cannot comment on that.
    Regards
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Pedro Ithier
    April 1, 2009 at 2:42 am
    Hi my name PJ and I have a problem with my MC. First I was working without problem using my 8 gb p2 card the I switched to a new 16gb p2 card. First my laptop didn’t recognize it . So I tried with a new driver. So my laptop was able to find the card. But now when I play any clip in avid using the DNA (mojo Sd) It hangs up the application. The problem only occurs when using the mojo with a P2 card in the PCMCI slot. My work aroud is to use the consolidate feature to copy the content of the p2 card and then work. But I need to play direct from the P2 to save time.
