Activity › Forums › Avid Media Composer › Mojo Problem / Avid DIO Runtime Error
Posted by Danorst on November 8, 2006 at 3:56 pmI have Xpress Pro 5.6 on my system and I recently added a used mojo. I
Danorst replied 19 years, 10 months ago 3 Members · 5 Replies -
Michael Hancock
November 8, 2006 at 7:59 pmGo to http://www.ccleaner.com and download ccleaner. It’s a great free utility that helps to get rid of rogue files left over from bad uninstalls, as well as other files not necessary for your system to run. It’s safe–I’ve used it on two personal system I have at home and it helped get rid of all kinds of crap (I think that’s what the first C in ccleaner stands for). Run it and see if it can help you out.
Otherwise, and you might hate to hear this, but a fresh install of Windows will likely help. Clear everything off, back everything up once or twice, then just start everything over. Of course, make sure you have all of the other programs you need that are also installed on this machine.
That’s all I have to offer for now–I’ll see if I can find more out about this though and will get back to you if I do. Good luck!
Mike.
Danorst
November 8, 2006 at 8:12 pmAlright I’m about to try CCleaner now ~ sounds like a great idea… anything over re-nstalling windows.. I just installed the Windows in October and hope to go a few months before I need to do it again. I’ll let you know how it goes
Danorst
November 8, 2006 at 10:03 pmYes it worked! – thanks so much…
But now I found I am back at the original problem. After reinstalling the DIO Runtime and plugging in the mojo the computer doesn
Dave Schweitzer
November 8, 2006 at 11:47 pmAre there any other devices on the firewire system with your mojo?
On Macs the mojo won’t function unless it has the firewire bus all to itself, maybe the same for PCs?
