Activity Forums Avid Media Composer MOJO clip light and no incoming Audio
  • MOJO clip light and no incoming Audio
    Posted by Mike Drew on November 1, 2005 at 11:35 pm
    Hi all, got a problem with a Mojo. Cant get it to capture audio on both the RCA’s and DV inputs. Have checked cables etc and re-flashed firmware but no joy. As soon as you open the capture tool, the clip light on the Mojo comes on and stays on. When you switch to DV input the light goes off but no audio there also. It does playback existing media that is already captured. Any thoughts? Help!!!!
    Tried all combinations of re-starts and deleting settings, MC states etc cant find anything on th KB either.
    Mojo passes POST.
    Video is fine.
    Xpress Pro 4.3.1 and tried 4.5.1 HPxw8000. This system has been rock solid for 18 months since install.
    Thanks for any help
    Mike Drew
    Bill Coyle replied 20 years, 9 months ago 2 Members · 1 Reply
  • Bill Coyle
    November 9, 2005 at 11:32 pm
    I have 4.6 and mojo and was recently frustrated by the same problem. It fixed itself, and I have no scientific path…BUT….
    I went to the audio input/output settings via the audio meter, and flipped thigs back and forth, and rebooted. I also made sure the digitize settings were in DV input before the reboot, and made sure the DV deck was on and had a tape in it when rebooting…(cold, a new restart). Everything woke up at that point.
    Hope this helps, BC
