Activity › Forums › Creative Community Conversations › Mojave fcpx egpu support
Posted by Tom Sefton on September 25, 2018 at 10:19 pmhttps://support.apple.com/en-mz/HT209134
Co-owner at Pollen Studio
http://www.pollenstudio.co.ukMichael Hadley replied 7 years, 10 months ago 9 Members · 14 Replies -
Eric Santiago
September 26, 2018 at 4:56 amExciting times ☺
Now all we need is a new Mac Pro with Thunderbolt 10 😉
Bill Davis
September 26, 2018 at 5:33 pmI’ll just add that on virtually ALL the FCP X insider chat streams, the word appears to be “Migrate SLOWLY” and take care. Apparently Mojave includes some pretty deep changes – and this update, more than most, won’t be a just “go ahead and click and update” transition.
Just a FYI.
Creator of XinTwo – https://www.xintwo.com
The shortest path to FCP X mastery. -
Steve Connor
September 26, 2018 at 6:26 pm[Bill Davis] “and this update, more than most, won’t be a just “go ahead and click and update” transition. “
I did just that and so far……….. It’s very good, not a single plugin is broken!
Oliver Peters
September 26, 2018 at 8:53 pmThe only thing about this eGPU implementation is that it is a toggle – either/or. It doesn’t do anything to combine the power of both the internal and the external GPUs.
– Oliver
Oliver Peters – oliverpeters.com
Michael Hadley
September 27, 2018 at 10:58 amHopefully next version of FCPX is optimized for eGPU so that it uses BOTH internal and external gpus.
Currently, it’s not particularly help because it requires the newish Thunderbolt 3 and I would imagine most newish computer used by pro editors have pretty good gpus. But: if you could harness dual gpus, then you’d really have something.
Tom Sefton
September 27, 2018 at 12:07 pmThe reviews I’ve seen seem to hint that performance is split between the two by using the external for playback and internal for encoding tasks. Hopefully there will be a way of combining both but I haven’t seen evidence that works on any OS.
http://www.pollenstudio.co.uk -
Erik Lindahl
September 27, 2018 at 6:28 pmI think DaVinci Resolve can use both the internal and external GPU. Not sure that’s always (or ever) the best practice for performance.
I can do some tests! 🙂
Oliver Peters
September 27, 2018 at 7:10 pm[Tom Sefton] “The reviews I’ve seen seem to hint that performance is split between the two by using the external for playback and internal for encoding tasks”
That’s the default unless you set the preference to the external.
– Oliver
Tom Sefton
September 27, 2018 at 7:46 pmInteresting. So an iMac pro with a huge gpu in an external enclosure could be an absolute beast of a machine
