Activity Forums Adobe After Effects Moire pattern when working with 3d shape layers and lights
  • Moire pattern when working with 3d shape layers and lights
    Posted by Manuel Rodrigues on September 25, 2014 at 8:32 pm
    Hi There,
    Im working with 3d shape layers and lights and this combination generates strange circles. A moire like pattern. Please see image below.
    (Shape look 3d but is actually a fat surface)
    At first I thought is was the banding problem which one can fix but adding rgb noise or something like that but this looks completely different. And it does not go away when I add RGB noise or set the project to 32 bit.
    What can I do to fix this?
    Thanks in advance!
    Manuel
    Roland R. kahlenberg replied 11 years, 12 months ago 3 Members · 6 Replies
  • Manuel Rodrigues
    September 26, 2014 at 7:41 am
    When I disable the lights the banding is gone.
    I’ve tried to play around with the material settings of the shape layers and the default setting don’t generate this pattern but when i pay around with the diffuse, specular, shininess and metal settings they appear…
    EDIT:
    Its when I set cast shadows to yess and a layers are on the exact same plane that the pattern appears…
    Anybody have a clue how to solve this?
    Edit:
    I have the z position, x and y rotation parameters of these planes hooked up separately to wiggle scripts of which i can manipulate the size and rate by sliders. Setting the z offset and x and y rotation to 0,2 results in a visible of set in position and does not solve the banding.
  • Manuel Rodrigues
    September 26, 2014 at 10:47 am
    Resolution is at 100% and full res, fall off of the light is set no none, changing this to smooth does not resolve the problem.
  • Michael Szalapski
    September 26, 2014 at 1:58 pm
    So, if you separate the layers in z-space, you don’t get it? Separate them then.
    It’s an issue of it trying to cast shadows and such.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Manuel Rodrigues
    September 26, 2014 at 1:59 pm
    For future reference of other users which might encounter the same problem:
    Solved by changing the angle in which the light hits the 3d shape layers..!
  • Manuel Rodrigues
    September 26, 2014 at 2:03 pm
    Hi Micheal,
    As I tried to point out in a previous post i tried to separate them in 3d space. I already had a wiggle script attached to the z axis and could thus set all separate shape layers to a smal offset (0.2 pix) in z space. Even tried to rotate them very slightly but this did not work. Changing the angle in which te light hit the shape layers solved my problem.
    Thank you for your input anyhow!
    Now back to work 😉
  • Roland R. kahlenberg
    September 26, 2014 at 6:40 pm
    This is an age-old problem with the Advanced/Classic 3D Renderer which has had issues with drawing shadows. ‘Solutions’ include using the ray-trace renderer, switching off shadow-casting and re-positiong/re-orienting lights.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
