Activity › Forums › Blackmagic Design › Moire On Analog Capture – Decklink Studio
  • Moire On Analog Capture – Decklink Studio
    Posted by Peter Tours on November 27, 2009 at 10:10 pm
    Just got DL Studio 2 card, used it last week to monitor my HD P2 project in FCP7, and also to output to Beta. All went fine. Now for the first time I am capturing from Beta – via component analog – and I am getting moire on the FCP capture screen and in my captured video, though not as harsh. I have recabled, shaken, tried options – cannot figure out how to access composite or s-vid for comparison.
    Anyone have any idea what is going on here? The moire is definitely not on the tape.
    Thanks for any suggestions:
    Declink Studio 2, Mac 7.3.2 driver
    Mac Pro Dual Quad 2.8 (early 2008)
    10gb ram
    Sony UVW1800
    OS 10.5.8
    FCS3, FCP 7.1
    Joshua Helling replied 16 years, 10 months ago 3 Members · 14 Replies
  • 14 Replies
  • John Pale
    November 28, 2009 at 5:31 am
    Can you connect the deck directly to a monitor?
    Might be the deck or cable.
  • Peter Tours
    November 28, 2009 at 10:51 am
    Thanks but the way my rig is set up, the VTR and FCP (Decklink) are monitored on 2 different channels of the same monitor so I can see the deck straight on input A and FCP (Decklink) on input B, both via S-Vid – and I switched them as a cross check. And also looked at the composite out of the deck on input C where I monitor with TC out of the deck. The moire is only on the capture window and the output of the FCP (Decklink) and of course in the captured media. Seeing it in the capture window is what concerns me most and where it looks worst, in capture and playback.
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
  • John Pale
    November 28, 2009 at 5:31 pm
    Could be electrical too…are the deck and your computer on the same circuit… Not trying to get Blackmagic off the hook…it’s just that there are a lot of variables involved, especially with older analog equipment.
  • Joshua Helling
    November 30, 2009 at 6:25 pm
    That’s definately odd. Tried that on our system in house and don’t see any sort of Moire pattern.
    I think it’s a good idea to try the Composite or S-Video inputs. To access those click Apple -> System Preferences -> Decklink. Once there there is an input dropdown. Click the dropdown and select S-Video or Composite (make sure you don’t leave the color channels connected while using these inputs).
    Let us know how it goes.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Peter Tours
    November 30, 2009 at 9:16 pm
    JOSHUA – I TRIED THE S-VID INPUT AND DISCO’D THE COMPONENT CABLE AND DID A TEST. THE S-VID LOOKED FINE – NONE OF THE ARTIFACTS OF THE COMPONENT CAPTURE – ALSO NOT GOOD ENOUGH TO USE IN MY SHOW AT S-VID QUALITY.
    I AM UPLOADING A SHORT MOVIE TO SHOW YOU THE PROBLEM. THE FIST CUT IS S-VID CAPTURE AND THE SECOND IS COMPONENT. THERE IS A DETAINLED DESCRIPTION ACCOMPANYING THE CLIP.
    I HAVE TRIED 2 COMPONENT CABLES SO FAR WITH ALMOST NO DIFFERENCE IN THE COMPONENT CAPTURE.
    Peter Tours
    Fort Lauderdale, FL
  • Peter Tours
    November 30, 2009 at 9:26 pm
    THE LINK TO THE CLIP IS
    https://f1.creativecow.net/405/peter-tours-example‘>405_ptourstest2quicktimeh.264.mov.zip
    Peter Tours
    Fort Lauderdale, FL
  • Peter Tours
    November 30, 2009 at 9:51 pm
    Being the thorough type, I managed to borrow yet a 3rd component BNC cable – still the same as the first two. Staying in the cable realm for a moment, now that you have seen the video, could it be the breakout cable?
    Whatever it is, I really gotta work it out before the end of the week. I can always re-capture before I finish as long as I can get a clean component capture.
    Thanks, Peter
    Peter Tours
    Fort Lauderdale, FL
  • Peter Tours
    December 1, 2009 at 7:58 pm
    B&H is replacing it.
    Peter Tours
    Fort Lauderdale, FL
  • Joshua Helling
    December 1, 2009 at 9:52 pm
    Okay…so i’ve downloaded your file. And yes, I see the Component looks obviously worse than the S-Video. Color is different as well as the there seems to be some green in the back wall.
    So, first I would ask if you’ve changed the color settings in the video adjustments area. Each may need independant settings.
    Another thing, is to rule out any weird compression anomolies can you check both of these captures in uncompressed.
    Sincerely,
    Joshua
    Director of Support
  • Peter Tours
    December 2, 2009 at 12:36 am
    Joshua – I captured as uncompressed 10 bit with no difference. The color sliders are all in detente (do you actually need to move these?!?) and Use Betacam Levels is checked.
    Frankly I have done about everything I can do – the people @ B&H say they have heard or this problem before so you should really talk to them. I can forward the chat log I had with them today.
    Very simply, I took my AJA IO LA out of the system, installed your card, reconnected the cables and you see the result.
    B&H is overniting me another unit to try, so I will post the results then.
    I believe I have already provided my personal email and cellphone to you and your assistant who spoke to me on the phone today when you were unavailable. I think at this time discretion says further communication should take place along those channels, don’t you?
    Peter Tours
    Fort Lauderdale, FL
