Activity Forums Adobe Premiere Pro MOGRT vi script
  • MOGRT vi script
    Posted by loris grifa on February 6, 2025 at 3:54 pm
    Hi guys,
    i’m having a problem with mogrt via script, but i can’t find any solution. Maybe someone can help me so i will share the scenario.
    I’m injecting mogrt via script, taking the text content from a formatted sheet, and the injecting works well, but once the mogrt is in premiere timeline the text box panel in the ‘properties’ tab is empty.
    Under the Effect control everything works fine and once I change the text in the effect control on the properties panel the text suddenly appear on the other tab. The real big problem of this situation is that if a try to retrieve the text style via code i can see only the text value. After making visible the text on the other panel i have access to the complete string, showing style info.
    Moreover i think there is no other workaround to access the text style…
    I would like to have your opinion.
    Thank for your support.
    Roland R. kahlenberg replied 1 year, 7 months ago 2 Members · 1 Reply
