Activity › Forums › Maxon Cinema 4D › mograph: step color transition
  • mograph: step color transition
    Posted by Ronny Traufeller on September 29, 2013 at 8:10 pm
    hey everybody,
    i was just thinking, i have a plane, and i want to use the poly fx to sort of control each polygon
    of the plane. wich works great if i use like a random effoktor to turn them.
    now i was thinking to also use a shader effector to have different colored polygons. like a gradient, but not smooth gradient, like the next clone has 10 % more yellow then the one before und so on. just steps.
    i think i saw it somewhere but google didnt bring much joy this time
    thanks,
    Ronny
    traufeller.de
    Ashish Gupta replied 13 years ago 3 Members · 3 Replies
  • Adam Trachtenberg
    September 30, 2013 at 4:45 am
    Unfortunately you can’t control color with Polyfx, but you could use a Fracture Object instead.
  • Ronny Traufeller
    September 30, 2013 at 9:26 pm
    Okay i understand, but i am also interested to create the color transition, do you have a hint for that too? Thanks very much, ronny
    traufeller.de
  • Ashish Gupta
    October 1, 2013 at 8:42 am
    Ronny,
    I put together a scene file using the formula effector on color mode .. It works as it is supposed to on a cloner but not on a fracture object .. The object index seem to be messed up after disconnecting the plane in the fracture object and i can’t figure out why ..
    Changing the polygon index in structure manager doesn’t seem to work either ..
    If you break up planes in separate objects(polygon groups to objects) and then change the position of first plane in the hierarchy to the last then it works ..
    Here’s the scene file :
    6587_formulaeffectorcloneswithincreasingcolorvalue.c4d.zip
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
