Activity › Forums › Maxon Cinema 4D › MOGRAPH : shader effector to select clones ?
  • MOGRAPH : shader effector to select clones ?
    Posted by Andy Stokes on May 16, 2007 at 9:20 am
    Is there any way to use a shader effector to control where to place cloned object(s) on a grid ?
    In it’s simplest form i’d like to have two objects in a cloner grid. The objects would be placed on the grid relative to a b/w image. For example Black would be object A and white would be object B.
    Hope this is clear… Any ideas?
    Cheers,
    Andy
    Adam Trachtenberg replied 19 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 16, 2007 at 2:02 pm
    Yes, you can certainly do that. You just have to check the “visibility” box in the shader effector’s parameters.
