Activity Forums Maxon Cinema 4D MoGraph Plane Effect
  • Adam Trachtenberg
    June 14, 2010 at 10:02 pm
    Here’s one way to do it: 833_displacewipe.zip
    The displacement deformer shows the displacement in the editor. The displacement is produced by an animated noise. It’s wiped off with an animated gradient which is set up as a mask channel in the layer shader.
  • Tom Slattery
    June 14, 2010 at 10:20 pm
    Excellent. Thank you!
    ~TPS
