Activity › Forums › Maxon Cinema 4D › MoGraph Multi/Color Shader + Delay Effector?
  • MoGraph Multi/Color Shader + Delay Effector?
    Posted by Darby Edelen on January 25, 2012 at 10:02 pm
    Hey guys, C4D R12 here. I am having a hard time figuring out how to get an effector to alter the shaders on cloned objects with a delay effect. It’s become apparent that the Delay Effector only applies to PSR transforms as can be seen in the attached video.
    Delay Effector + Multi Shader = No Love
    Is there a way to create a delay in the Color Shader or Multi Shader as well?
    Darby Edelen
    Darby Edelen replied 14 years, 8 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    January 26, 2012 at 5:38 am
    Try using falloff on the effector that’s making the color change.
  • Darby Edelen
    January 27, 2012 at 6:56 pm
    The effector is a plain effector with a falloff the size of one of the cloned cubes. It’s moving through the array of cubes causing them to change color and move up 1 meter on the y-axis. After that a delay effector is applied.
    I’m not sure how to add an additional falloff to the effector, and even if I could I don’t think it would work as desired (like the delay effector). The falloff would have to be somehow aligned with the direction of travel of the effector, and then whenever it made a turn it would cause all kinds of wonkiness.
    If you have something specific in mind that I’m overlooking please let me know!
    Darby Edelen
