Activity Forums Maxon Cinema 4D MoGraph Multi-Shader Problem
  • MoGraph Multi-Shader Problem
    Posted by John Macenroy on February 22, 2012 at 10:19 am
    Hi there,
    Im desperately trying to figure out a problem that occured in a current c4d project of mine.
    I used the MoGraph Multi-Shader on a Cloner in combination with a Random Effector to create a Videowall showing different Videos and everything works fine to that point. However I need to rounden the edges of a that cloner object so that it matches the outline of a logo. I did that with a boole object that I used on the Cloner but as soon as I do that the Video wall only plays one single video.
    I attached 2 pictures of my problem to show you a little bit better.
    I hope you can help me.
    https://s8.postimage.org/kenduze0h/Bild_1.png
    https://s8.postimage.org/44x7s33ch/Bild_3.png
    John Macenroy replied 14 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 23, 2012 at 12:25 am
    The pictures are too small to see what’s going on, but I don’t think that what’s you’re trying to do is going to work. The boolean is a generator object, meaning that it generates new geometry from two objects. The resulting geometry doesn’t have the mograph information that the multishader requires.
    Only workaround I can think of would be to make the boolean editable and put all of the resulting objects into a cloner.
  • John Macenroy
    February 23, 2012 at 9:40 am
    Thanks for your explanation of the boolean object generator, always grateful for your help here. I guess I just have to work around it.
