Activity Forums Maxon Cinema 4D mograph matrix object tp + pyrocluster, cant rotate per keyframes..
  • mograph matrix object tp + pyrocluster, cant rotate per keyframes..
    Posted by Ronny Traufeller on May 22, 2012 at 3:37 pm
    following (setup for a earth with clouds)
    -mograph matrix (object mode, generates tp) + sphere as object
    -particle geometrie
    -envirement + pyro tracer
    clouds look great!
    but,
    all grouped in a null, i simply wanted to turn the earth
    including the clouds but they seem to hold there position.
    so now i rotate the cam to continue but want to make a camera animation
    and now i stuck…
    how to move the sky? 🙂
    traufeller.de
    Adam Trachtenberg replied 14 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 23, 2012 at 2:25 pm
    If you’re animating the rotation of the sphere the particles should follow along.
