Activity › Forums › Maxon Cinema 4D › MoGraph Clones in Clones – How To drive multiple plain animation with 1 Field
  • MoGraph Clones in Clones – How To drive multiple plain animation with 1 Field
    Posted by Don Lavender on September 20, 2023 at 9:50 pm
    Hello and good day! I have a MoGraph animation of rotating cubes with an object on top. The rotation is being driven by a plain effector and a spherical field with a vibrator tag. I would like the objects on top of the cube to scale down as the cube rotates. I’ve put the geometries inside a cloner and have added a new plain effector to scale the objects down using the same spherical field that triggers the plain effectors rotation.
    The problem I’m running into is that. When I hit play, and the first object is triggered, all of the objects in each clone scales at the same time without being triggered or the objects all at once sort of pulses briefly at 100% then goes to its original scale and never animates. The clones also highlight when this happens.
    I’m thinking it might have something to do with that I have a clone inside a clone. If so, hoping there is a workaround.
    Thanks so much!
    Kouraib Abdmalek replied 3 years ago 2 Members · 1 Reply
  • Kouraib Abdmalek
    September 21, 2023 at 8:23 am
    Hi Don,
    If you could post your file here to let us check it that will be better.
    thanks!
