Activity Forums Maxon Cinema 4D MoGraph Cloner (Object) question
  • MoGraph Cloner (Object) question
    Posted by Christopher Colbourne on November 9, 2011 at 2:32 pm
    I’m trying to create a simple marquee light box with round bulbs going around the box – but for whatever reason, I keep running into the issue that when using a rectangle spline/path, the objects don’t seem to lock/snap into the corners to give you more of an even distribution.
    I thought I saw a tutorial trick once about this type of issue, but be damned if I can remember WHERE when I need it!
    Any help would be greatly appreciated! 🙂
    Richard Dunstan replied 14 years, 10 months ago 2 Members · 5 Replies
  • Richard Dunstan
    November 9, 2011 at 3:21 pm
    could you upload your c4d file? what you’re trying to accomplish is not so clear, but a guess would be that you answered your own question, set the distribution to even.
  • Christopher Colbourne
    November 9, 2011 at 3:33 pm
    Essentially, I drew a rectangle to use as the “object”, then drew a simple sphere to clone (that would resemble marquee lights that would flash around a billboard).
    Sometimes when I’m spacing, the spheres won’t snap into the corners to make it an even distribution.
    I’m just wondering if there’s a way to “force” that type of snapping into the corners for a more realistic distribution.
  • Richard Dunstan
    November 9, 2011 at 3:59 pm
    a .c4d file is worth more than a billion words
    here is an example of what I think you’re trying to accomplish, if you set ditribution to even then everything should work out..animate the offset and you have them moving around your spline, evenly.
    3228_example.c4d.zip
    November 9, 2011 at 4:31 pm
    3231_c4dlightissues.c4d.zip
    There’s an example file of what the issue is I’m discussing.
  • Richard Dunstan
    November 9, 2011 at 5:06 pm
    looks to me like they stick to the corners ok, I’ve animated the spheres and it looks ok to me, but maybe I misunderstood..
    3232_example3.c4d.zip
