Activity Forums Maxon Cinema 4D mograph: cloner in cloner, time offset
  • mograph: cloner in cloner, time offset
    Posted by Eatmydear on March 17, 2007 at 4:17 pm
    hello,
    i have some troubles when using a mograph cloner object inside another cloner object.
    the source i am cloning is a simple cube which has a scale animation.
    then it seems the time offset of a step effector will just work on the first cloner but not with the second one.
    i hope someone here can help me with that.
    cheers,
    markus
    Adam Trachtenberg replied 19 years, 5 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 18, 2007 at 5:02 pm
    How are you expecting the time offset to work with the second cloner? In other words, have you actually animated the first cloner so there’s something to offset?
  • Eatmydear
    March 18, 2007 at 9:20 pm
    the only animation i have is the scale of the cube, that is my source object to clone.
    the first cloner makes 5 cubes vertical and has a step effector applied. that works fine, the 5 cubes start scaling with an offset.
    so the second cloner makes clones of the previous clones in horizontal direction. and here i want to have an offset as well.
    doesn’t work with another step effector. is there a way to do it?
    thanks for replying!
  • Adam Trachtenberg
    March 21, 2007 at 3:13 pm
    I think there is a way to do it, but not the way you’ve gone about it. The offset animation function only works with keyframe animation.
    I think what you’ll have to do is copy the original cloner and manually offset the keyframe animation of the cloned cubes.
