Activity › Forums › Maxon Cinema 4D › MoGraph arrow head alignment problem
John Hammond replied 17 years, 2 months ago 4 Members · 15 Replies
Jack Evans
June 30, 2009 at 11:36 amHmm… I still can’t get that poke-through fixed. Not sure what I’m doing wrong (again, complete C4D noob here) but it won’t accept any changes to the P.Z value for the cloner object at any frame. I change the value, then it blinks back to what it was before. I can change the position value of the arrow head object, but that doesn’t do anything; the sweep object continues to follow it. It looks like the end of the sweep object is tied to the center of the arrow head; I’m wondering if the sweep were following a null object parented to the arrow head, if it would work differently.
I’m ordering the live version this week, I’ll try it again once it arrives (maybe there’s a patch that covers it that didn’t make it into the demo). Since the problem is reproducible and the scene file here is pretty basic, I would think it wouldn’t be too hard for the engineers to track down if someone sends in a bug report.
John Hammond
June 30, 2009 at 11:56 amHi Jack,
The Arrowhead’s positions are firstly arranged in a radial pattern by using the Cloner Object (mograph). This cloner then flies around the circlePath through the use of the Align to Spline tag on the cloner. (animating position %).
To adjust the arrow’s position you can alter the original object’s pivot point, or add a plain effector to the cloner and adjust the position params.
However, I don’t think this issue is related to the crazy render I am getting . . the geometry is jumping around all over the place (see render above).
Jack Cook
June 30, 2009 at 12:13 pmJohn, I don’t know if this is exactly what you’re looking for, but here’s a tutorial about how to make an object follow the growth of a sweepNurbs object. I’ve used this to make an arrow grow in a similar way to what happens in your file.
Jack
Jack Cook
June 30, 2009 at 12:15 pmI forgot to put in the link. Here it is:
https://www.base80.com/index.php/2007/01/29/align_to_spline_xpresso#more1
Jack
John Hammond
June 30, 2009 at 12:43 pmCool, thanks JAck. I’ve use Xpresso a little like this tuts first example.. But this tut goes deeper with the vector2matrix and matrix to HPB.. I need to work through that and try to understand it!
Cheers.
