Activity Forums Maxon Cinema 4D MoGraph Array not working when using Hair – Cinema 4D
  • MoGraph Array not working when using Hair – Cinema 4D
    Posted by Valentino Laz on February 1, 2020 at 1:28 pm
    Hello,
    I have been trying to create an array of an object with hair and unfortunately the hair does not come through.
    The hair is stuck on 1 object in the array and is not dispersed across all the duplicates.
    I have looked online and cannot find a solution.
    Any ideas on what the issue is? Why is the hair not been seen by the array?
    Hierarchical Set up:
    – Array
    –Null
    Hair
    Subdivision surface
    Ball
    Valentino Laz replied 6 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    February 1, 2020 at 7:09 pm
    you can put the Array in a Connect Object and then add the hair to that
  • Valentino Laz
    February 2, 2020 at 10:53 am
    Thanks for the tip but unfortunately that didn’t work, all objects disappear when applied under the connect object.
