Activity Forums Maxon Cinema 4D Mograph and Net Render issue
  • Mograph and Net Render issue
    Posted by David Wiffen on August 6, 2009 at 3:29 pm
    Hello Chaps,
    I have a scene where I have cloned trees on a landscape. There are hundreds of trees duplicated onto a surface. This is exactly what I need. Problem is when I come to net render, each machine picks a different way of duplicating the trees on the object surface. So the final effects is dancing trees!
    I tired making the cloner editable, but the problem is I am using a mograph shader as a way to vary colours on trees to reduce the computer generated feel of it.
    Is there a way to stop this happening?
    Thanks in advance
    Adam Trachtenberg replied 17 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 7, 2009 at 5:27 am
    The MoGraph cache tag should fix it for you.
