Activity Forums Adobe After Effects Modifying the keyboard shortcuts prefs file? (effect shortcuts)
  • Modifying the keyboard shortcuts prefs file? (effect shortcuts)
    Posted by Peter O’connell on May 14, 2005 at 4:22 am
    Hi I am trying to customize my keyboard shortcuts for AE by changing the prefs file in text edit. Mostly I want to add a few shortcuts for effects I use often. I tried adding
    “Levels” = “(Option+Shift+L)”
    to the long alphabetical list near the end of the file and then deleting the menu item that had that shortcut, but alas it doesn’t work. Anyone ever make a shortcut for an effect in AE?
    PS. yes I backed up the original prefs file.
    Any advice would be greatly appreciated.
    Pete
    Peter O’connell replied 21 years, 3 months ago 2 Members · 2 Replies
  • Filip Vandueren
    May 14, 2005 at 11:21 pm
    I believe the only things you can assign shortcuts to are those that are allready in the txt-file, so there’s no way to add a shortcut to this or that Filter.
    I’m sure there are third-party apps that can add custom keys to menu-items. depends on your OS
  • Peter O’connell
    May 15, 2005 at 7:26 am
    Thanks for your post Filip, Too Bad eh. I use mac os 10.4 by the way.
    Take it easy
    Pete
