Activity Forums Adobe After Effects Expressions Modifying 2-D expressions to 1D values
  • Modifying 2-D expressions to 1D values
    Posted by Navarro Parker on November 19, 2012 at 10:18 pm
    I’m using Dan’s standard “Creating Trails” expression:
    delay = thisComp.layer(“Delay Null”).effect(“Slider Control”)(“Slider”); //number of frames to delay
    d = delay*thisComp.frameDuration*(index – 1);
    thisComp.layer(1).position.valueAtTime(time – d)
    And it works great for 2D position properties. But if I use the “Separate Dimensions” command, it breaks if I apply it to a “1D” property like X or Y individually. How can I modify it to work with just one dimension?
    Dan Ebberts replied 13 years, 9 months ago 2 Members · 1 Reply
  • Dan Ebberts
    November 20, 2012 at 1:39 am
    For xPosition, for example, you could change the last line to this:
    thisComp.layer(1).transform.xPosition.valueAtTime(time – d)
    Dan
