Activity › Forums › Apple Final Cut Pro Legacy › Modify FCP clip after roundtrip to STP or Motion
  • Modify FCP clip after roundtrip to STP or Motion
    Posted by Anmol Mishra on September 26, 2012 at 1:09 pm
    I am using FCP7 in FCS3.
    When use a roundtrip and send to Motion or STP, the stap or motn file replaces the original clip in my timeline.
    I have a format problem with Cineform, essentially FCP interprets all my Cineform clips as Upper Field instead of None Field Dominance.
    Is there a way I can access the underlying clips and re-render after changing the Format -> Field Dominance to None ?
    I noticed that this causes some stair stepping artifacts otherwise.
    Rafael Amador replied 14 years ago 2 Members · 3 Replies
  • Rafael Amador
    September 26, 2012 at 1:48 pm
    make sure the Cineform clips shows as Progressive (NONE) in FCs Browser before dragging them to the time-line. Th e time-line must be NONE too, and the Motion project the same.
    rafael
    http://www.nagavideo.com
  • Anmol Mishra
    September 26, 2012 at 4:07 pm
    Unfortunately many of these projects were created before I knew this..
    I have the project settings as None.
    Is there a way to access the clips in round tripped project to change their settings ?
  • Rafael Amador
    September 27, 2012 at 2:52 am
    no idea.
    the best solution when having problems round tripping is to export a self contained movie from Motion.
    rafael
