Modify clip drop frame timecode
I am trying to change the timecode on several longer clips within Media Composer and I’m running into a strange error.
First, here is the problem: we “crash” captured DVD screener footage with a timecode burn-in to assemble rough cuts. Later we will receive Digibeta source tapes of which I will re-capture at a higher resolution. Since there is no way to capture true timecode with the DVD screener footage, I thought I could simply capture the footage without timecode or with a randomly generated timecode and then go to Modify Clip and change the timecode to match the burn-in window timecode and vola everything matches up.
However, when I modify the timecode about 10 minutes into the DV-rez footage the Video TC changes from drop-frame to non-drop. No matter what I modify I can’t change the TC to stay drop-frame throughout the entire 40 minute clips…
The audio TC stays drop frame, but the video mysteriously changes to non-drop, thus throwing off the TC for the whole video after about 10 minutes into the clip.
What am i doing wrong, and how can i fix this?
