Activity Forums Apple Final Cut Pro Modify Audio to be at -12 db.
  • Modify Audio to be at -12 db.
    Posted by Adam Berch on September 15, 2015 at 12:19 am
    If I am adjusting my audio tracks to peak at -12 or 16db, is there a way to Modify Audio and pick the db you want it to be be peaked at (I did this in FCP 7 all the time) or do I just have to keep adjusting the volume until I get it to where I want it?
    John Rofrano replied 11 years ago 4 Members · 3 Replies
  • Bret Williams
    September 15, 2015 at 12:30 am
    How did you do this in FCP 7?
  • Craig Alan
    September 15, 2015 at 4:51 am
    normalize. and broadcast safe. used to act as limiters. not sure why -12? why not -6? haven’t used 7 in a couple of years so I might be wrong.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • John Rofrano
    September 16, 2015 at 2:29 am
    The answer can be found in the Audio Hard Limiter thread. Basically you set up the Compressor as a hard limiter and save the preset and then apply it to all of your audio clips with cut-n-paste, or else as a final step, make a compound clip of all of your audio clips and apply it to the compound clip before rendering.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
