Activity Forums Adobe Premiere Pro Modify Audio Channels for MOS
  • Modify Audio Channels for MOS
    Posted by Jim Wilcox on April 19, 2013 at 3:41 pm
    Using modify…audio channels from a bin to select active source audio (and creating presets!) works well for P2 media in CS6 except for MOS. When I set all four channels to None and then bring the clip into a sequence it won’t drop anything, just the international NO sign. If I bring the clip into the source monitor after modifying the audio, I can then successfully bring it to the sequence MOS but only by selecting the “Drag Video Only” icon.
    If I modify clips with audio on one or more channels using this same procedure, results are as expected.
    Is there a work around or am I missing something?
    Jim Wilcox replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
