Activity Forums Adobe After Effects Expressions modifing Charles’s Batch Processing script
  • modifing Charles’s Batch Processing script
    Posted by Antony Dupsta on October 10, 2018 at 7:18 pm
    Hello friends,
    I am using Batch Processor v2.5 from nabscripts
    When I run this script it defaults to multiple parameters that I change. Each time I run this script I have to uncheck the Default Square Pixels and manually change it to anamorphic.
    I also see it defaults to output module 01. I click the drop down and select module 02.
    I went through the script looking for a way to modify this code or see if the settings would be remembered to avoid continually manually entering in these steps each time I launch this script?
    Any help or thoughts on this would be excellent. Thanks
    Antony Dupsta replied 7 years, 11 months ago 1 Member · 1 Reply
  • Antony Dupsta
    October 10, 2018 at 7:56 pm
    I may have figured this out with a little more trial and error.
    this.omLSelDflt = 0;
    change this to the module number that reflects your needs. In my case 1 which is the second module.( Adobe uses 0 as the first, all numbers are offset by -1. 0=1, 1=2, ect)
    this.parLstChoices = ‘[“Anamorphic 2:1 (2)”‘;
    This should allow the script to default to 2:1 instead of 1:1. As you can see I took away all the other choices forcing it to anamorphic.
    search of these parameters in the code to track these down.
    remember to use // in front of the original line to disable it if you want to reinstate the original code later down the road.
    I will probably forget all this and want to know this in a few years from now. Future me says thanks in advance.
