Activity › Forums › Creative Community Conversations › modified file problem in multicam edit
  • modified file problem in multicam edit
    Posted by Tamir. Azoulay on January 14, 2014 at 11:41 pm
    Hello everybody.
    In my first multi cam project in Fcx I’m having serious problems.
    first, as i here in the tutorials i change all the files to proxy mood and start to edit multi cam ( it was vary fun)
    afterwards i’m switch back to original or optimized media – and i Surprised to find that all the media that was edit in multicam is modified files..
    i tried to relink the file from the event but no Success
    someone can help please..
    Tamir
    Jeremy Garchow replied 12 years, 8 months ago 2 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    January 15, 2014 at 5:11 am
    If you double click the multicam edit, select the “modified” file, and hot command-shift-r to reveal in Finder, is the media on your hard drive OK?
    Jeremy
  • Tamir. Azoulay
    January 15, 2014 at 9:29 am
    In the finder everything also show as modified..
  • Jeremy Garchow
    January 15, 2014 at 1:14 pm
    What is the source of the media (what camera was used)? Is it optimized media, or is it original media?
    If it’s optimized (in a “High Quality” folder). Trash all the media out of the high quality folder and regenerate the optimized media.
    If it’s Original media, trash it and reimport the media.
  • Tamir. Azoulay
    January 15, 2014 at 10:51 pm
    After i Delete i don’t have any option to transcode – see the photo
    The camera is canon c100
  • Jeremy Garchow
    January 15, 2014 at 10:53 pm
    C100 shoots what kind of media? AVCHD?
  • Tamir. Azoulay
    January 15, 2014 at 10:55 pm
    yap. AVCHD!
  • Jeremy Garchow
    January 15, 2014 at 10:57 pm
    Please show me where you deleted the media from.
    Jeremy
  • Tamir. Azoulay
    January 15, 2014 at 11:05 pm
    i Delete the optimize and the original
  • Jeremy Garchow
    January 15, 2014 at 11:07 pm
    You should only delete the optimized if there’s optimized.
    If you have deleted the original as well, you should reimport the material.
    Jeremy
