Activity Forums Maxon Cinema 4D Modelling used tissues (cloth dynamics??)
  • Modelling used tissues (cloth dynamics??)
    Posted by Paul Rijkaard on January 27, 2016 at 12:02 am
    I would like to model a group of screwed up tissues, kleenex.
    I have been experimenting with cloth dynamics onto a plane, and letting it fall into different containers, but this tends to look like a fallen silk handkerchief and instead I want to make twisted, contorted, standard scrunched up tissue balls.
    does anyone have any suggestions? or any pointers to online resources.
    Much appreciated
    Brian Jones replied 10 years, 8 months ago 2 Members · 3 Replies
  • Brian Jones
    January 27, 2016 at 8:41 am
    Need to know more about shape of ‘standard tissue ball’ really fully wadded sphere or not, do you have ref pictures?
  • Paul Rijkaard
    January 27, 2016 at 10:35 am
  • Brian Jones
    January 28, 2016 at 4:33 am
    fairly tight to fairly loose… and cloth just relaxes things so no good unless you make it very stiff and then it doesn’t crumple. You’d have to pre-make the form probably with Set Point Value (look for crumpled paper/tin(aluminium) foil threads/tutorials) then use Softbody dynamics to give it some spring when dropped. Though maybe some of the rounder forms could be faked with a soft body that’s been deflated (pressure)
