Activity › Forums › Maxon Cinema 4D › Modeling: Used a SubDivision, now want to use a deformer..
  • Modeling: Used a SubDivision, now want to use a deformer..
    Posted by Kelly Johnson on November 12, 2015 at 10:00 pm
    If I’ve used a SubDivision to smooth an extruded spline out and I now want to make that an object where I can then use a deformer, how can i do that?
    My layers look like:
    Subdivision Surface
    -Extrude
    –star-base (the spline I drew)
    This has been a general question of mine…how to take a model one has created via use of deformers and such, and then “expand” them so that they are a single object as if you’ve pulled down a sphere, cube, cone etc.
    I’m making a stylized figure whose body is somewhat like “Duke” the java mascot from some time ago and so far, drawing the spline for the overall shape, extruding that spline and then rounding it off with the subdivision surface has been my way.
    I thought about just building it ‘blocky’ and then subdivision surface, but then when I would want to use a deformer, I’d be in the same boat.
    Brian Jones replied 10 years, 10 months ago 2 Members · 1 Reply
  • Brian Jones
    November 13, 2015 at 1:27 am
    deformers work either as the child of an object or at the same level as an object in a group (usually in a null)
    so, either
    Subdivision Surface
    -Extrude
    –star-base
    —deformer
    or
    Null
    -deformer
    -Subdivision Surface
    –Extrude
    —star-base
