Activity › Forums › Maxon Cinema 4D › Modeling an Engine (Motor)
  • Modeling an Engine (Motor)
    Posted by Darren Kunkel on September 8, 2009 at 4:49 pm
    Hey Guys-
    …. been looking high and low for any and all tutorials on creating an Engine/Motor. I’ve started creating a motor utilizing simple box modeling, but at this stage would appreciate any/all feedback on known resources/samples for this type of project.
    Thanks in advance to all the helpful folks on this Forum.
    -Darren
    Darren Kunkel replied 17 years ago 2 Members · 3 Replies
  • Will Salley
    September 11, 2009 at 4:22 am
    I don’t know of any tutorials specific to “engine modeling”. You could try some tuts on polygonal modeling and boolean technique. That gets you through many engineering oriented objects such as pistons, cranks, cylinder heads,etc.
    Use 3D snapping settings to define a scale and tolerance.
    Will you animate? If so, find some MOCCA tutorials, or, if you have Dynamics, some tutes on that as well.
    Ditto with Pyrocluster for the sparks and smoke. But a basic engine should be no problem with the base package.
    Primary System Info –
    Mac Pro 2×3.2 Quadcore – 10.5.8 – QT 7.6.2 – 20 GB RAM – nvidia8800GT – SATA internal & external storage – Blackmagic Multibridge Pro (Not Functioning)- Open GL 1.5.10 – Wacom Intous2 tablet – AJA io
  • Darren Kunkel
    September 13, 2009 at 12:39 am
    Thanks for the response Brian-
    -D
  • Darren Kunkel
    September 13, 2009 at 12:40 am
    …make that Will 🙂
