Activity › Forums › Maxon Cinema 4D › Modeling a Cassette
  • Modeling a Cassette
    Posted by Stefán páll Ívarsson on January 19, 2012 at 3:59 pm
    I took on a mission to make a few seconds video of a hovering cassette. Because I thought I had a good hunch on how to do it.
    What I did was:
    1) Made a path in photoshop
    2) Rendered them to C4d by saving for illustrator
    3) Started dividing the paths to splines and then extruding nurbs on them
    ((4)) My plan then (if 3 would’ve worked) was to chop up the original image
    and place it on the nurbs, so it would have the same look, but it’d be in 3d.
    Now, this didn’t work for me, because when I extruded the nurbs, I had holes
    in the middle of my cassette which I didn’t know how to fill in, and for that same
    matter I didn’t know how to make one of my path to be a hole in the cassette.
    In the end, my questions are:
    1) What is the most efficient way of using nurbs from paths? (for my project)
    2) Is it possible to place an image on a polygon/area and make it fit so it looks real?
    3) Do u have any other tips for me?
    Really appreciate any help on this, thanks.
    The image I’m trying to 3dalize:
    https://www.twoandseven.com/wp-content/uploads/2011/12/Memorex_Cassette_Tape_by_Cliffski.jpg
    Tony Barone replied 14 years, 8 months ago 2 Members · 1 Reply
  • Tony Barone
    January 19, 2012 at 4:57 pm
    As with everything, there are a few ways to accomplish what you’re looking to do here. One way is to combine your splines, the outline of your cassette and the holes, into a single spline and then extrude that.
    To do that, select the splines you want to combine (The outline of the Cassette and the Hole/s) then Right Click one of the selected Splines in the Object Manager and go down to: Connect Objects + Delete.
    This will combine your Splines into a single Spline which you can then extrude.
    Another way would be to extrude the objects separately and then use a Boole Object to Subtract the Holes from the Cassette.
