Activity › Forums › Maxon Cinema 4D › Modeling a bottle
  • Modeling a bottle
    Posted by Alberto Hernandez on February 26, 2011 at 5:49 am
    I need some help. I´m making a 3D model of a bottle, but the bottle need a ribbon, like a necklace. I was trying whit splines but by the form of the bottle it is impossible to match. I also tried drawing around the bottle (the part between the body and the mouth) whit bezier curves but it is difficult. There is a way to adapt a form to and object?
    Alberto Hernandez replied 15 years, 7 months ago 4 Members · 4 Replies
  • Randy Johnson
    February 26, 2011 at 1:55 pm
    If you have cloth you can use the dress o matic option.
    Or you can make a copy of the bottle a delete what you dont need and model from that. This gives you the option to model with polys or you can convert the edges to splines and go from there.
    /Randy
  • Adam Trachtenberg
    February 26, 2011 at 3:20 pm
    There are other options as well:
    * Stucture>Edit Spline>Project (spherical mode), to conform splines to the object;
    * Shrinkwrap deformer;
    * UV Deformer;
    * Model in place using polygon snapping.
  • Andrew Wilson
    February 27, 2011 at 12:39 pm
    Isn’t using a lathe nurb is easiest way to model a bottle? Not sure about adding the necklace though. Sweep nurb maybe?
    Andrew Wilson
    WestView Digital Video & Design
    http://www.westviewdigital.com
  • Alberto Hernandez
    February 28, 2011 at 10:51 am
    Thak you guys. I will try all the options. Wait for my results. Thank you.!
