Activity › Forums › Adobe After Effects › Mocha tracking issues
  • Jon Merrifield
    December 27, 2014 at 3:29 am
    I love mocha and use it all the time. Great tool.
    Here’s the thing, it takes a little getting used to. You need to know how it thinks and what it does with the data. Find any tutorials you can, especially those from Imagineer and AdobeTV. and/or continue searching on the Cow and you will discover your solution.
    Virtually always an “off track” is one of these things:
    You or I have not set and/or pasted to the proper start frame.
    Yours or my tracking clip and our comp are not the same size. (Pre-render your track clip to be the same size and match placement in your comp)
    Something else is off sync like frame rates etc…
    cheers,
    Jon Merrifield
    PELi VFX
  • Jack Zehnder
    December 27, 2014 at 3:36 am
    Thanks, will do.
