Activity › Forums › Adobe After Effects › Mocha tracked data applying nothing to composition
  • Mocha tracked data applying nothing to composition
    Posted by Rowan Cavanagh on November 13, 2018 at 10:15 am
    First time using Mocha properly, so no doubt this is my fault somewhere along the line.
    I’m trying to track a phone screen through Mocha, using what I assume is the norm of x-spline and planar surface tools, with a bit of AdjustTrack stuff along the way. This part seems to work fine, as you can see from my video.
    What doesn’t, is when I head back in to After Effects and try to apply this tracking data to a composition, containing a phone screen image. It doesn’t seem to bring anything through into the effects panel or once I apply a corner pin effect to the target layer.
    Help?
    Have a look at what I’m doing here – https://www.dropbox.com/s/lop72i8pr615r5z/applying%20tracked%20data.mp4?dl=0
    I’m using After Effects CC 2019 and therefore the new Mocha plugin.
    Update:
    Considering I can’t reply to my own post (because I’m new?), I’ll put this here.
    I’ve worked it out. The answer is pretty annoying, but relieving.
    I hadn’t checked this little processing cog next to the layer created in Mocha (which I didn’t know was there), when selecting the track:
    Hopefully this helps someone in the same position one day!
    Rowan Cavanagh replied 7 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
