Activity Forums DaVinci Resolve Mocha Tracked But Can’t Use in Resolve 18.5+
  • Mocha Tracked But Can’t Use in Resolve 18.5+
    Posted by Lillian Young on August 29, 2023 at 2:00 pm
    I tracked a face using Mocha Pro from the Color page of Resolve 18.5.1. If I use Resolve’s native tracker, I can apply an effect on that clip and it shows, eg. the Beauty plug-in onto a face.
    So here’s what I did:
    After tracking a face in Mocha Pro (launched from the Color page in Resolve), I saved that track in Mocha and returned to Resolve. There, after I dropped a Beauty effect on the serial node, the Mocha plug-in disappeared from the Settings panel and the Beauty effect is applied to the full clip instead of just the part I tracked.
    Any help would be appreciated.
    Lillian Young replied 2 years, 9 months ago 2 Members · 2 Replies
  • Steven Martillo
    August 30, 2023 at 10:16 am
    hello Lillian! you need to import the alpha that you have obtained from mocha pro, you can do it automatically with the same plugins that in this case did not work for you, or import that alpha manually and take it to fusion then create an alpha entry coming from fusion but in the color module and there you would have the possibility to apply that effect only to the tracked part in mocha pro.
  • Lillian Young
    December 3, 2023 at 2:20 pm
    Thank you, Steven!
