Mocha AE Suddenly Crashes After Effects 2021 on closing + No Autosave
H, Everyone.
Today, all of a sudden, whenever I close Mocha AE, After Effects crashes. Also, for some reason Autosave has stopped working.
The only thing I did today was install an extension from Adobe exchange called Motion Bros, as I was trying tio follow a tutorial on how to do a face replacement using it. The tutorial proved to be a rabbit hole towards buying other software, so I stopped and tried to use Mocha, but now my After Effects is useless.
It won’t autosave and Mocha crashes the system.
I’ve restarted countless times, deleted the Motion Bros extension, re-installed After Effects, pured all the cache. Can anyoneone suggest any other fixes?
I am working on Mojave on After Effects 2021 (I have little choice on this as my editorial team are on it to run an earlier version of Avid). I can run a newer version of After Effects on a different partition, but it is such a pain to work on that because I can’t access Avid and pull shots into After Effects there very easily.
Any help would be much appreciated. Thanks.
