Activity › Forums › Adobe After Effects › Mocha AE puzzle
  • Mocha AE puzzle
    Posted by Adam Taylor on August 15, 2013 at 2:44 pm
    I have tracked a shot in Mocha – fairly simple 1 layer with no masks. It does have sheer and perspective selected.
    the track looks great in Mocha – the grid locks to it, the built in logo locks to it.
    Yet when i export the transformation data, paste it into a Null (then delete the Anchor Point keyframes) and parent the replacement logo to the null, the result looks terrible, with the graphic wandering around all over the place.
    Any idea what i might be doing wrong?
    adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
    Roland R. kahlenberg replied 13 years, 1 month ago 3 Members · 4 Replies
  • Kevin Snyder
    August 15, 2013 at 4:09 pm
    Don’t delete any keyframes after you paste the tracking data in AE. Also, make sure you are pasting the keyframes at correct location in your comp.
  • Roland R. kahlenberg
    August 15, 2013 at 4:11 pm
    Did you really export Transform data from mocha or was it Corner Pin data?
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Adam Taylor
    August 16, 2013 at 9:53 am
    kevin – every tutorial i have seen from Mocha shows the Anchor Point keyframes being deleted. Its worked for me in the past, and if you don’t delete them, the effect does nto work.
    Roland – yes, definitely the Transform date (i also tried the corner pin just in case but not what i needed!)
    I have solved the issue by going back to FCP and exporting the shot rather than sending it to AE via an XML.
    Re tracked the exported shot and it worked with very little finessing.
    c’est la vie!
    adam
    Adam Taylor
    Oldham, UK
    August 17, 2013 at 3:57 am
    I’m glad you’ve solved your issue. I’d like to add that when exporting Transform Data to AE, other than deleting Anchor Point keyframes, you should also reset the value of the Anchor Point – if you’ve used a Null, the value should be [0,0]. You could of course right-click on the value and selected Reset from the Contextual Menu.
    Most tutorials skip this reset. The benefit of the reset is that the Null now visually moves directly over the tracked area. There is no benefit to the tracking result but the Null’s position is now positioned more intuitively as it conforms 1-1 to the tracked area.
    Cheers
    RoRK
