Activity › Forums › Adobe Premiere Pro › mLogic Rocket -> iMac -> Premiere playback issues?
  • mLogic Rocket -> iMac -> Premiere playback issues?
    Posted by Jay Thomas on April 7, 2014 at 6:21 pm
    Hi all. I’m experiencing playback issues in Premiere when engaging a Rocket in an external chassis:
    iMac 3.5GHz Intel Core i7
    32GB 1600 MHz DDR3
    OS 10.9.2
    Premiere Pro CC
    Red Rocket inside mLogic Chassis via Thunderbolt. Drivers and firmware updates all installed.
    Media on GRAID 3Tb with plenty of free space, via Thunderbolt
    5K r3d media
    When the rocket is not in the loop, I can play this media in Premiere fine at 1/8 and often even at 1/4. However, when the rocket is engaged (and Premiere is told to use it via the Clip Source Settings), I can’t playback this media at any setting. I’ve encountered this on a separate edit station with a similar setup, the only difference being one station has a second thunderbolt monitor and the other does not, but the results are identical.
    The rocket very clearly adds processing and playback improvement in Red Cine on this same media, so I know it’s working and working well.
    So I’m fine working in Premiere with my system without the rocket – but confused as to why the rocket negatively impacts playback instead of helping. Should I conclude that this configuration (iMac, external chassis, Premiere, Thunderbolt 1) is just not workable? Or am I missing something?
    Many thanks.
    Jay Thomas replied 12 years, 5 months ago 2 Members · 2 Replies
