Activity › Forums › Adobe Premiere Pro › MJPEG codec and premiere
  • MJPEG codec and premiere
    Posted by Naaman Meir on May 22, 2008 at 6:43 am
    hello
    i work with premiere cs3 for editing outdoors movies i film with a sony dv cam and i just added a camera for underwater video (https://www2.oregonscientific.com/shop/browse.asp?cid=6&scid=14)
    the camera films on flash card with a mjpeg codec at 640×480 at 30fps
    i usually work with dv pal 25fps
    now i have an ffdshow filter codec installed for mjpeg
    and i try to mix the mjpeg cam with the dv cam , usually for very short
    pieces of underwater footage in mjpeg.
    the problem is that premiere usually crashes while tryin to edit thos files togther with other dv parts , usually just after adding them to the project while CONFORMING the files but also after cuting them on the timeline , and sometimes even while rendering to disk , if i get to that point…
    also the rendering process , even for preview of the pieces from the mjpeg take alot of time compare to the dv , like 10 minutes for 1 minute piece…
    i was trying to convert them to dv with an extrnal software before
    adding to premiere but then i allways get a file with black side frame , and it makes it difficult to edit like that , i think its because the camera takes 640×480 resolution and not NTSC.
    if i do a convert for each file one by one with the premiere in a project that is 640×480 and i just render it to dv pal its fixing it but it takes alot of time to render long videos and since i have alot of videos like that i need a way to do it all in one click and let it run over night and with premiere its only one at a time…
    so is ther any program to convert them in a good resolution?
    or any fix for working with mjpeg ? maybe different codec?
    thanx.
    naaman
    John Cerletty replied 18 years, 3 months ago 3 Members · 3 Replies
  • Vince Becquiot
    May 23, 2008 at 4:02 am
    640×480 should be fine if the camera records in square pixels, since that roughly translates to 720×480 in D1 NTSC.
    The codec is the issue. I would try importing it by itself and then export uncompressed. Or using AE, which is more likely to play nice.
    Vince
  • Naaman Meir
    May 29, 2008 at 12:39 pm
    ok , this is what i do now , i set an 640×480 mjpeg project
    and import 1 file at a time , export to dv pal
    and get the file in dv full screen in good quality
    the problem is i have ALOT of files on each shooting
    so im looking for a software that can do that in batch
    with good results , or a way to batch in premiere ,
    i need to try the after effects , can it batch?
    i dont know how to work it out yet, …
    thanx
  • John Cerletty
    June 19, 2008 at 6:39 am
    Hi
    For downloading free MJPEG or other Image codecs u can go through at free site such as http://www.free-codecs.com etc. But as u’ve mentioned above tech spec. May be u can go through some Codes trading portal such as design-reuse, chipestimate or IPsupermarket.com. although many devlopers/companies procure optimized MJPEG codecs for devlopement purpose. so it cost you
    I would suggest define you needs. free one i can provide u no of links.
