Activity Forums Apple Final Cut Pro Legacy Mixing XDCAM HD and DV SD 4:3… a workflow?
  • Mixing XDCAM HD and DV SD 4:3… a workflow?
    Posted by Alessio Gemma on December 19, 2009 at 4:14 pm
    Hello,
    I need to mix XDCAM HD 422 1920×1080 50i clips with older DV PAL 4:3. I nvedr did this job, so I’d like to get some guidelines from you.
    I guess that the first step is to conform the 4:3 clips to the HD size: have I to use Compressor for this job?
    DV is lower first field dominance, while XDCAM top first: have I to deinterlace the clips (doing this in Compressor)?
    A workflow will be strongly appreciated!
    Regards,
    Alessio
    Alessio Gemma replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
