Activity Forums VEGAS Pro Mixing Pcm/Ac3 on same DVD?
  • Mixing Pcm/Ac3 on same DVD?
    Posted by Gerald Stokes on July 9, 2008 at 3:45 am
    Hello
    I am making a music video with 3 audio tracks, I want 1 in PCM and the other two AC3. I can’t seem to be able to do this. DVD-A either wants to convert all to AC3 or you can pick PCM in properties, but then all 3 tracks are rendered in PCM and huge!
    On a side note, I have several commercial DVD’s where you can see the title(in text) of the DVD when you press the display or info buttons on your remote. Can you input the DVD’s name with DVD-A so it shows up when you press display info?
    thanks
    GS
    Gerald Stokes replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
