Activity Forums Apple Final Cut Pro Legacy Mixing PAL and NTSC in timeline — Out of Sync Audio
  • Mixing PAL and NTSC in timeline — Out of Sync Audio
    Posted by Eva Ikari on March 5, 2009 at 9:01 pm
    I have a PAL timeline, and mostly SD PAL assets. I had one SD NTSC asset that seems to work fine in the PAL timeline.
    But I’ve just received an HDV NTSC asset, that is out of sync when dropped into the PAL timeline.
    Is there an easy way to fix this or am I just going to have to convert the HDV NTSC media into another format? Should I just convert it to SD or should I convert it to PAL SD?
    Rafael Amador replied 17 years, 6 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 6, 2009 at 12:28 am
    Eva,
    FC can manage different sizes and codecs in the same sequence without much problem, however when talking mixing different time-base FC can not.
    You may use Compressor or the Nattress Standard Conversion Plugin.
    Rafael
    http://www.nagavideo.com
