Activity Forums Maxon Cinema 4D Mixing Materials ?
  • Mixing Materials ?
    Posted by Tom on June 26, 2007 at 11:57 pm
    How do I take multiple images/textures and blend them together?
    Is there a shader tree concept?
    Do I use a special “tag” between my materials?
    TH
    Tom replied 19 years, 3 months ago 3 Members · 3 Replies
  • Nolan Scott
    June 27, 2007 at 12:58 am
    Well, there might be different ways to do this…
    Try this : create 4 different textures and drag them all on to a sphere /
    make sure that at the first texture-tag
  • Adam Trachtenberg
    June 27, 2007 at 5:09 am
    The other way to do this is to use the Layer Shader within a single material. The layer shader works similar to Photoshop or AE, so you can add as many layers as you want, change blending modes, use masks, folders, etc.
  • Tom
    June 27, 2007 at 6:13 am
    Two excellent suggestions!
    Both methods work quite differently and are equally as useful + !
    Cheers.
    TH
